Default Site Voice
jghumphrey
I am setting up a multi-site system and want to have a consistent "voice" across all sites and audio clips. It makes no sense to me that I can change the default site language but not the voice and I don't want to have to recreate everything with a different voice. Nothing personal "Kevin", but you are not the voice I want representing me.
5 REPLIES 5
FORE-Craig
Hi @jghumphrey
You can set up the all of the recordings in Phone System Management > Assets Library with the Voice that you would like. I prefer "Matthew" over "Kevin". Haha
After they have been set  up there, you can tie the same messages into the individual sites under Company Info > site name > Settings > Default Audio Prompt.
I hope that helps!
Craig
jghumphrey
Thanks, Craig, but that is exactly what I want to avoid. Changing multiple greetings for multiple sites would be completely unnecessary if the default voice could be changed.
FORE-Craig
You're welcome! I don't think I understand what mean though, @jghumphrey.
You still need to create a set of default audio prompts to customize what you want them to say (as text to speech, or recorded audio) for events such as Greeting & Leave Voicemail Instructions, Leave Voicemail Instructions, etc for regular, closed and holiday hours.
How would having a default voice change that?
Craig
jghumphrey
There is already a whole set of audio prompts defined for various situations in Company Info | Site Name | Settings | Default Audio Prompt. I would like to not have to recreate these to use a different voice.
FORE-Craig
I understand!
Craig
