Zoom AI Companion2024-03-20 05:57 PM
Hello Everyone
In Zoom Auto Receptionists it's is possible to have sub ivr
Example if the user press 1 (Registration)
under Registration we want to have 2 option
New Registration (1)
Exisiting /Follow up registration (2)
Go back to main Menu (3)
Is this possible ?
Solved! Go to Solution.
2024-03-22 11:49 AM
@elcapitan-ph Yes, it is possible to create a multi-level interactive voice response (IVR) system.
You need to create another Auto Receptionist (Registration) that will serve as your sub IVR and call queues for New Registration, Existing and Follow up registration.
For the Registration Auto Receptionist:
For the Main Auto Receptionist:
2024-03-22 11:49 AM
2024-03-27 02:20 PM
Hi @elcapitan-ph ! I have reviewed your post and @crissyd has replied with the correct solution, so I've gone ahead and marked it as an accepted solution. Please let us know if you have any additional questions!
