Hey, @ICEEFT_ops,
I’ve never experienced this issue, but I think the same approach used to solve “music over the microphone” might help you.
But first, I have to ask: Are they using just one computer? If so, the solution below will probably help. But if there are two computers in the same room, usually feedback is the big issue – two computers can only be used in the same room of both users are using headsets, generally speaking.
Read this Zoom Support article on Original Sound – I think if the couple uses this in their end, it might solve the problem. It’s not complicated, but there are a few steps to getting it set up initially; after that, they should see the Original Sound button in the upper left of their Zoom screen.
