Zoom showing arrow when using pen with small tip
PatrickR
I use a Yealink MeetingbarA20 with Zoom. When i use a pen with a small tip the software shows a arrow( see attachements) Is there a way to disable this funtion?
1 REPLY 1
RN
Zoom Moderator
Zoom Moderator
Hi @PatrickR, unfortunately, I don't believe you're able to. Currently, our product team reviews all feature requests submitted via our feedback form https://zoom.us/feed. I highly encourage you to submit this feature!
I'm curious though, can you share how your Yealink MeetingbarA20 is set up? Is it a part of your Zoom Room? If so I wonder if we can try to disable windows setting with the Zoom Rooms for Touch (windows only), you can try to change all the settings about pen in Start > Settings > Devices > Pen & Windows ink. Try disabling visual effects and show cursor if enabled.
Zoom Community Moderator
he/him/his
