Zoom AI Companion2024-05-23 09:41 PM - edited 2024-05-27 10:19 PM
After setting the MTG from the zoom schedule, I will send an attendance request to both A and B from Outlook at the same time.
A receives the correct meeting link, but for some reason B receives the old meeting link.
Both of them use Outlook on Android. They received an invitation email in outlook, and when B opens the attached ics file, it is a past mtg invitation.
Solved! Go to Solution.
2024-05-25 05:21 PM
Hi @Hiroyuki_49
Try the following steps to resolve the issue:
1. Remove the meeting invitation from your calendar.
2. Refresh your Outlook calendar to ensure it's up-to-date.
3. Open the new ICS file you received and re-add the meeting invitation to your calendar.
This should update the meeting details and resolve any issues
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
2024-05-25 05:21 PM
Hi @Hiroyuki_49
Warm regards
