2025-05-09 09:42 AM
There's a way for the Zoom App to bypass DnD and Sleep Focus by adding Zoom in "Allow Notifications", however if the phone is on silent, it will only vibrate.
Is there a way for Zoom to bypass silent mode by forcing it to have an audible ringtone, similar to when you tag a phone contact in iOS as "Emergency Bypass"?
2025-07-23 08:30 AM - edited 2025-07-23 08:31 AM
Following up on this. If you enable CallKit:
In the Zoom app:
Go to More > Settings > Phone > General and enable "Use CallKit to receive calls when not on Zoom Workplace"
It will route zoom calls to your iPhone as a specific number/contact. You will then just create a contact for that number, and add Emergency Bypass to the Ringtone/Text Tone in the contact, and it will bypass DND/Mute and play that ringtone.
