2022-03-24 06:42 AM
Which field and values in the CallLog do we use to identify Internal calls? Off-net vs on-net?
2022-03-24 06:53 AM
From our KB document, here are some of the details for From and To columns that may describe what you are asking about.''
The following points explain the columns in the log table to help you identify log entries:
in certain scenarios
For complete details on different areas on call history logs. Kindly see the full KB article below.
2022-03-24 07:15 AM
Hi there, this is referring to the call history logs download from the portal. Is there a similar documentation for the CallLog API endpoint?
2022-03-28 09:36 AM
Hi @kalel
Check out if this would help, it shows the current APIs available for Zoom Phone. https://marketplace.zoom.us/docs/api-reference/zoom-phone-api
