Starting July 10, 2024, customers must add their phone numbers to an approved 10 DLC campaign in order to keep using SMS/MMS capabilities on their numbers.
Register now for an upcoming 10DLC Enforcement Webinar.
Zoom AI Companion2021-08-12 03:33 PM
This my camera problem, when I use it in skype or just open the camera it works perfectly fine, but when using zoom is a total problem. PLEASE HELP I TRIED ALL!
2021-08-13 01:15 PM
Not sure I understand the problem. Can you give some more details.
2021-08-16 07:08 PM
This looks like the problem I am having! I have checked all settings and can't seem to find a solution. Basically, the cameras, both front and rear facing, are zoomed in to the right side area of where the actual camera view should be. So I have to move way right to center myself in the view and it is zoomed in a bit. I use any other app with the cameras and this is not a problem.
Also, it is only from my own personal viewpoint. I tested it with a friend and my video looked just fine on their end. It was not zoomed in at all.
Please help!!
2021-08-19 10:27 AM
I am having the same problem.
2021-08-19 10:28 AM
2021-08-20 01:03 PM
Looks like a different camera all together. Are you sure you have the correct camera chosen in Zoom?
2021-09-14 12:00 PM
Tenho o mesmo problema, já alterei todas as configurações do Windows e não funciona no Zoom. Estou perdendo reuniões importantes.
2021-10-13 01:48 AM
same problem, every setting checked right
2022-03-09 06:48 AM
This is looking one of the most common issues that I faced with zoom app some days ago but as you can seehere some information about its solution here check it out.
