  • Starting February 3, 2025, Zoom Phone customers must add their phone numbers to an approved 10DLC campaign in order to use SMS/MMS capabilities on their numbers.
  • Introducing more live support options! More Zoom customers now have access to live agent chat support. Sign in and visit our Contact Support page to see all your available support options. We’re here to help!
Problem with Zoom Breakout Rooms
Donald-B
Hello all, I am having problems with using zoom breakout rooms. I am assigning meeting participants manually to the one of the two rooms we normally create, to give on average 8 to 12 participants in each room. There is an issue that some participants are are not in the room assigned, as there is no green dot to the left of their name. What do I do in this case ? Do I wait or try again to manually assign them ?
The second issue I have is when late-comers arrive to join the Zoom meeting. I had a case when I manually assigned a late-comer to one of the breakout rooms. The person was not immediately assigned. In fact it took 2 to 3 minutes for this to happen. A frustratingly long delay if you are the Zoom host. If anyone in the community could guide me it would be appreciated.  Thank you.    Donald
2 REPLIES 2
Ohkawa
@Donald-B
When a participant is assigned to a breakout room, the assigned participant is shown the message that he/she has been assigned to the breakout room and will not join the breakout room until OK is pressed.
It would be smooth to inform the participants in advance so that they can press OK.
Thanks for your reply to my posted question Ohkawa. Best wishes
