Audio setting not supporting chanting sound
AbhijeetP
I am a yoga instructor. Zoom audio settings are suppressing my Omkar "AaaaUuuuMmmmmm" chanting. I tried with all settings of Original audio, removing background noise settings but failed to fix it. Tried with different microphones as well.
I have ensured that the issue is not with microphone device/ system settings as using same device for other applications like Google meet is working fine.
Would appreciate if someone can help with this ?
Just to go in details, while chanting Omkar and pronouncing "AaaaUuuuMmmmmm", it only captures initial "Aaa" and then it starts blocking most of the sound.
3 REPLIES 3
You do NOT have "original sound" turned ON. Check the upper right part of the Zoom window for "Original sound for musicians off" and click that link to turn it ON.
doesn't work
Sara108
any luck? I ama facing the same problem
