All,
I have a case open since April or May of 2020.
Apparently, if you would like to route your calls using Call Handling, it does not work for t-mobile.
Example:
Call Handling 1: Zoom Application
Call Handling 2: T-Mobile
Call Handling 3: VoIP Phone
If someone calls my direct number (Zoom), it will ring Max 15 seconds then it will (or should) ring my t-mobile number. If I don't pick it up then it will ring my voip phone. That's how should it works.
Well...it does NOT work. After the Zoom app max ring time, it just skips Call Handling 2 and goes directly to Call Handling 3. It does not matter where I put my t-mobile in order using the Call Handling feature - it just skips the t-mobile phone.
For months I've been going back and fourth with Zoom support and finally convinced the Zoom tech support to find co-workers who has t-mobile phones and use the Call Handling feature. He did and confirmed that there is an issue with t-mobile phone numbers. He had escalated the ticket # to the Telephony DevOps Team and we should hear back from them. Well...it has been 6 months already no update. Even though I've been having this problem since my company start using Zoom phone back in April of 2020.
Hopefully this post will catch someone's attention (Zoom) and push for this to be resolve.
