Get work done more efficiently with Zoom AI Companion. The AI Companion Onboarding Center is now live!
Learn moreEmpowering you to increase productivity, improve team effectiveness, and enhance skills.
Zoom AI Companion2024-02-22 12:13 PM
We recently made our own setup for the sort of Town Hall meetings.
We have a Rodecaster Duo, 2 wireless mics of the same brand a Logitech Rally camera, and a speaker. We are using a Zoom Room license that runs on a Mac Mini and an iPad as the controller.
The setup work overall okay except that there is one meeting, yes one in particular, where people that are connected remotely have echo when they talk. Interestingly, we have another meeting using the same devices and setup where there is no echo.
Some of the things that I noticed are:
Curious if anyone experienced anything like this or if you have a way to fix the problem or keep troubleshooting. Also, if you have tips to work around this problem in the meantime that could be helpful as the communication isn't full duplex someone has to mute our room to stop the echo. As there are too many people is hard to troubleshoot when all are on the call.
2024-02-23 11:48 AM
You are trying to do a very complex audio setup. If you are using speakers for a local live audience so they can hear Zoom participants - that is an echo feedback source. Echo is delayed feedback and typically comes from sound out from a speaker feeding back into a mic (that can be local or from any participant having speakers on) or not using a proper mix-minus when mixing all the sound sources. Most likely based upon your comments the feedback is coming from the speaker in the local room. Local sound must have isolation between the mics and the speakers. Each time you open another mic you must lower all mics by 3db. For isolation all mics need to be behind the speakers and the speakers need to be kept as low as possible. If you are using the rodecaster Duo to feed Zoom participant audio to speakers it does NOT have mix-minus capability. Since the Neat bar is probably at the screen then the mics are in front of the speaker and are picking up participant audio. If you insist on using multiple omni-directional mics then consider providing earpieces for listening rather than using a speaker. Yes there are technologies that can mic everyone in a room with a speaker, but it is beyond most peoples budget since it is in the $5000+ range. What you are attempting to do is very complicated and you might want to consult a specialized engineer (and yes I too am an engineer specialized in A/V and broadcasting).
2024-02-27 10:16 AM
thanks, @storyhub for the answer.
I'll try to find an A/V engineer who can help us with this.
I'm curious about your opinion if this is something that can be tackled using the noise gate and/or the high pass filter that the Rodecaster Duo configuration brings.
Thanks again.
