Zoom events: Save button for setting up session doesn't work
EAFG
Hi all,
I'm trying to set up the agenda in Zoom events for a conference. When adding an agenda manually, the save button does not turn blue and I can only cancel my entries.
Do you know how to fix this or what I did wrong?
1 ACCEPTED SOLUTION
DeniseLahat
Yes, this is a tricky onw.  You need to make sure that when you enter TRACK that you press ENTER.  THen you will be able to save the session.
3 REPLIES 3
DeniseLahat
BrendaByers
I have entered TRACK and all other required fields and I also tried entering all fields the SAVE never turns blue?  I've even tried recreating the conference.  No go.  It will into let me create 'any' sessions.
DeniseLahat
see attached
