2022-09-21 10:44 AM
I am hosting a webinar and cannot figure out how to disable the raise hand function. I thought I used to go into the participants, and I selected "Disable raised hand", but it is not there anymore.
Solved! Go to Solution.
2022-09-21 11:51 AM
You're right on the mark there! If you're the webinar host, co-host or panelist you'll see the option to disable hand raising in the participant's tab > click the 3 dot ellipses. Photo attached
-If you're not the host, it's possible the host has this feature disabled.
If you're not seeing this option, please ensure all prerequisites are met in the article below:
https://support.zoom.us/hc/en-us/articles/205566129-Raising-your-hand-in-a-webinar
If this answers your question, please accept as solution.
2022-09-21 11:51 AM
2023-09-08 10:14 AM
I am also facing same issue. I am using version 5.15.7 but did not found such option to disable hand raise even I am the host.
2023-09-08 06:52 PM
Welcome to the Zoom Community, @shashisbs.
Disabling the Raise Hand feature is only available in a Webinar. If you are in a meeting, disabling the Raise Hand feature isn't currently possible.
2025-01-15 09:15 AM
Hi Ray, I am not seeing this option on my webinar! How do you do it?
