2024-08-12 10:05 AM - edited 2024-08-12 10:09 AM
My Zoom version is 6.1.6 (43767), used on a windows desktop 64-bit operating system, x64-based processor, Intel(R) Core (TM) i5-7400 CPU @ 3.00GHz 3.00 GHz.
I use the desktop app : Zoom Workplace
Everything worked fine until I was forced to update my Zoom desktop app to 6.1.6. 10 days ago.
The problem is:
While sharing a power point presentation (slide show) with students, if I play an audio file inserted in that presentation, the students can’t hear a thing.
I can hear the audio document although the volume appears down.
Students can still hear me talk and I can hear them.
The situation is the same on one screen or extended screen.
Surprisingly, a small number of ppt presentation work fine but the majority don’t.
I use the same software (MS ppt) and the audio files are all mp3 format.
So, I can’t understand why that is happening (sound being shared in some ppt documents and not in others)
Again, this issue only started recently with the Zoom version v6.1.6.
Yes, I am sharing the sound correctly, so 2 of the links below provided as support are of little help to me.
Anyone else with similar pb who was able to find a successful fix ?
Thanks for sharing.
Here are the links already suggested.
https://support.zoom.com/hc?id=zm_kb&sysparm_article=KB0065146
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0057913 and https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0063608
2024-12-10 01:30 AM
I'm also facing the same problem. And my zoom version is 6.2.11. For old mp3 files (created like 2-3 years ago), it seems ok. But the latest mp3 files suddenly stop working.
At first I thought it was the bit rate of the MP3. But even when I convert to WAV or reduce the bit rate, it still doesn't work.
2024-12-10 03:04 PM
Yes, that remains a problem for my online tuition; I will have to change to another program when my subscription with Zoom expires.
2024-12-19 12:33 PM
Hello @Illyarrie,
I'm sorry for the late response and inconvenience.
When sharing slides or a PowerPoint presentation, kindly double-check if the share sound is toggled.
Please let us know if this helps or if you need further assistance.
2024-12-19 02:43 PM
Thanks Yes, the "share sound" box is ticked. I've had numerous exchanges with the support dept of Zoom few months back. They are not interested in fixing the pb. OK; I am not interested in renewing my subscription for a product which is now inferior to what it used to be with a much much higher price tag.
