2025-11-03 08:15 AM
The internal mic on my PC does not work but my cell phone works as advertised. Can both the PC and the phone be used simultaneously to participate in a single Zoom session ? Thanx.
2025-11-03 12:21 PM
Hi @BewilderedBob - welcome to the Zoom Community.
Absolutely. You can use your PC for the video and your phone for the audio in the same Zoom meeting, it's the perfect workaround for a faulty mic.
I hope this helps, thank you.
2025-11-04 04:53 AM
I was able to join Zoom meeting in other way than Arleen mentioned (although I didn't think it was possible 😉).
What I did was:
1. Joined the meeting from my PC client. In audio/video settings window that shows before joining I've selected "No audio" option.
2. After that I've joined from my mobile Zoom client logged to the same account. Select a desired meeting from calendar and click blue Join button, not "Switch" that is being shown on top of screen when you are in "Home" tab.
In there I had my camera turned off, but audio was selected.
Order of joining does matter.
As a result - I've joined meeting twice, with camera enabled on my PC and with audio from my mobile device. Order of joining
