Problem since 2 week while using zoom with 4G
Flocavy
since 2 week while using zoom meeting to record my on line courses I meet several problems :
1/  my micro makes strange noises
2/  my connection is instable, and spot while recording.
si I am confused because before that it was ok
but since the two last weeks (approximatively) my reseau swich off as soon as I start using zoom.
I check the volume of  data that I can use per month and and don’t use a lot of date so I don’t think it is the problem.
dors any of you had the same issue??
thank for tour helps
1 REPLY 1
Shaimaa
Zoom Employee
Zoom Employee
Hi Flocavy
I think you need to check your Zoom application's updates if you go to https://zoom.us/download,
Also you could check your windows/mac updates and the sound drivers updates.
In case of the issue still exist we highly recommend creat a support ticket.
Please like any post that helped you; please mark solutions so others can find them!
