2025 CMX Awards
Vote now
Simulive webinars
Gwallin74
I'm looking to do a webinar with 2 presenters.  I think the best way to do this is record both presenters and merge them together.
Is this possible?
1 ACCEPTED SOLUTION
DeniseLahat
easiest is just to record the session in a Zoom meeting or webinar, and then link the recording for simulive.  You can record gallery view and/or use the spotlight feature.  Test it and check which recording you like best.  If you want to do post production editing then you can use the "replace recording" feature.  you may need to ask zoom to enable it on your account
Denise Lahat
_____________________________
Need more help? Hire a ZoomPro - https://zoompros.guru
and join our FB group https://www.facebook.com/groups/zoomeventpros
1 REPLY 1
DeniseLahat
Denise Lahat
