Master Report for Webinars?
AV2024
I see the ability to download reports post-webinar for each of the different categories of data (attendees, chat, etc). I need all of this and will end up putting them into a spreadsheet on separate tabs- is there one master report you can download for an event vs needing to download each of these as separate files?
1 ACCEPTED SOLUTION
bstrelko
No 😞
You can automate this using some scripting and API calls - might not be worth the effort to build, but I guess it depends on how frequently you need to generate these reports.
1 REPLY 1
bstrelko
No 😞
