Scheduler Issue
shadow22176
My Scheduler calendar was working fine last week.  Now i get the following message.  What could be causing this issue?
The host's availability could not be retrieved
Please contact the organizer to resolve their calendar connection
9 REPLIES 9
askmissa
I am experiencing this exact same issue. 😞
feldsteinparis
Has anyone been able to resolve this issue?  I can't send out my calendar link because it's errored. I chatted with support and they were unhelpful and "submitted a ticket" low priority.
benkirk
Is there a resolution for this? Experiencing issues...
kwuzooms
I’m seeing the same problem on a team schedule link with All Hosts Available. Is this a permission problem?
Update: After doing some more research, here is what I've discovered. When one of my users creates a team schedule and adds me, the admin, as a co-host, I get this error: The host's availability could not be retrieved. But when my user removes me as a host, it works. I'm thinking it's a permission issue with a non-admin user trying to access an admin user calendar.
Update: I figured out a workaround. As an admin, I create a team schedule first with myself as the owner. I add other users as co-host. Then I transfer ownership to another user and delete myself. I then have the user add me back in their zoom as a co-host and it all seems to work.
sagesoul
Also having the same issue.  Still no resolution?
SPJ1
Following. Same problem
SmileBoutiqueNy
The same thing for me
SmileBoutiqueNy
It's kinda hidden, but I found out what was it.
You need to reauthorise your Google or whatever calendar.
From the 'Scheduler' tab on your settings click on a little arrow next to your name and 'Share' button. You will see then that your calendar is not authorised. Authorise it and voie la
RonaldB
To resolve this issue, you may login to your web portal account then select Zoom Scheduler on the left navigation menu and select Accounts tab. Click on Re-authorised on the calendar and check your link again.
