Zoom AI Companion2023-03-09 06:13 AM
Is it possible to click on a phone number link on your computer and have it dial out on your desk phone instead of the Zoom desktop client? Thanks
Solved! Go to Solution.
2023-03-09 07:37 AM
Hi @Gibber99
Yes, there is a feature named Call Control from Desktop Client. Once you set up the feature, the Zoom desktop app acts as an intermediary and initiates the call on the desk phone. You can use either the feature named Click to Dial and Highlight to Call (depending upon how the phone number is formatted) with phone numbers on websites, in your contacts app, email client, etc.. So, you will want to look at both features to achieve what you want.
Call control from Zoom desktop client is supported on these models:
See the following support articles on setting and using the features:
https://support.zoom.us/hc/en-us/articles/4912628206477-Using-desk-phone-call-control
https://support.zoom.us/hc/en-us/articles/360027633731-Using-click-to-dial-and-highlight-to-call
I hope that helps!
2023-03-09 07:37 AM
Hi @Gibber99
I hope that helps!
2023-03-09 07:42 AM
Great, that's just where I was! Much appreciated for the response and information, Craig!
2023-03-09 07:46 AM
Excellent! You are welcome!
