Poly Edge B30 - Multicast template
kbudurka
Hi all.
I have a batch of Poly Edge B30 phones I purchased.
These are going in a store/shop environment.
I need to be able to hit a page button and have the message go over the phones and also the paging system in the shop.
With Yealink, I was able to do this very easily using Multicast and a provision template.
In my template, I use:
#KLB - Yealink T42S
#Paging Setting
multicast.paging_address.1.channel=0
multicast.paging_address.1.label=PAGE
multicast.paging_address.1.ip_address=224.0.1.116:8000
multicast.receive_priority.enable=1
##multicast.receive_priority.priority=
multicast.receive.use_speaker=1
##multicast.receive.enhance_volume=
##multicast.receive.ignore_dnd.priority=
multicast.listen_address.1.channel=0
multicast.listen_address.1.label=Store PAGING
multicast.listen_address.1.ip_address=224.0.1.116:8000
##volume = 1-15
multicast.listen_address.1.volume=15
linekey.5.label = PAGE
linekey.5.value = 224.0.1.116:8000
linekey.5.extension = 0
linekey.5.type = 24
I can't seem to figure out how to do something similar on a Poly B30.
Can anyone make a suggestion?
1 REPLY 1
Hi kbudurka,
This poly document for poly edge b series may be of assistance.
Paging and Broadcasting Messages (poly.com)
Here is the zoom support article on templates.
Creating templates for phone settings – Zoom Support
Thanks,  eliot
