Hey @I_Lakinger, you have the option in your Zoom settings to change the output of your speaker if you prefer to change speaker outputs.
Are your headphones Bluetooth or wired and are you able to hear sound through your headphones? Zoom recognizes devices that are compatible and gives permission for your speaker output. Would also suggest checking to update drivers, permissions, etc., at the Windows setting level. Maybe help to also uninstall Zoom, reboot your computer, and reinstall Zoom from https://zoom.us/download
Leverage
cool features and
how to's from the
Community Center. If my reply helped, don't forget to click the
accept as solution button!
