Sound Level
Pizvmja
Hello! What level of sound can be fed into the Zoom input?
-14 Decibel LUFS or even less?
Overload is often heard.
1 REPLY 1
RN
Zoom Moderator
Zoom Moderator
Hey @Pizvmja, I am not sure If I have the best answer for you, however, I'm curious as to why your input would be -14 decibels? Unless you're using your own audio mix configuration with a 3rd party platform, I don't believe we have any documentation on the decibel level within the client itself.
Leverage cool features and how to's from the Community Center. If my reply helped, don't forget to click the accept as solution button! ⤵️
