Issue: Sound bleed between breakout rooms?
JD_TAS
During events, we are having issues where clients in one breakout room can hear sound from a SEPARATE breakout room. Any help here?
Thank you,
JD
2 REPLIES 2
SA22
We had exactly the same problem today as well.  We split the participants into four breakout rooms but two of the breakout rooms could hear each other.  We tried to bring one of the affected breakout room participants back into the main Zoom call to see whether that solved the problem but even then we could still hear the other breakout room.  Any help or guidance would be appreciated as we've never experienced this before and this forum post was the only thing I could find about the issue.
Thanks
gritsdps
We had the same problem today as well.  We split the participants into four breakout rooms but all of the breakout rooms and the main room could hear voices from only one breakout room. I would appreciate any help on this issue. Thanks
