Audio Sharing Sound Quality Problem
Komson
I'm using Zoom version 5.7.5 (939), on laptop with AMD Ryzen 3 4300U chipset.
Everytime I share audio from my laptop, both audio sharing only or from presentation, participants will hear cracked sound (buzzy noise). The shared audio sound quality is very bad.
I did uninstall, restart, then reinstall, yet the problem is still persist.
I also have the problem of participants VDO may freeze from time to time as well.
I never have these problems on the previous update.
How should I fix these problem?
Thank you in advance for your supports 🙂
2 ACCEPTED SOLUTIONS
Komson
Hi all,
I found the solution of this audio problem.
I uninstall the Zoom. Then download and install the 64bit installer, the problem is almost gone, I mean the audio quality is much better.
Hope this help 🙂
Cabin7
Upgrading the latest Zoom version ... was worse - does not recognize my microphone at all (meaning zoom is completley unusable).
I went back to version 5.6.5 which works fine.
14 REPLIES 14
naomi
Hi
I have the same problem did you resolve this?
I still cannot solve the problem.
Some friends suggest me to adjust volume in windows setting, yet still cannot solve the problem.
So I will wait until the next update to see if the problem is solved or not.
Carolinatutuia
tengo el mismo problema y no se como solucionarlo
A mí se me solucionó el problema, desinstalando la versión que tenía y reinstalando una versión antigua, la 5.6.5 quedó perfecto 👌 ya se escuchan los videos bien
MNASPIRAN
https://zoom-us-zoom.en.uptodown.com/windows/download/3332055
I finally fixed the problem. I had done everything including a complete reinstall of Windows and nothing worked.  I just installed this version of zoom from earlier this year and all is back to normal.
Komson
Hi all,
Hope this help 🙂
Installing the 64bit installer solved the problem. Thank you
This resolved my headache of a problem too!! Audio would play distorted when I shared, but only for me. Thank you
goodhistory
Dear Komson
Thank you for your help!  I have solved same problem. !(^^)!
Cabin7
How did you go back to the previous version?  I have the same audio problem.
AZG_2021
Thanks for the help! I had the same problem and version 5.6.5 fixed everything!
martinasmith
our instructors were hosting a webinar about the best sublimation printers at sublimationtools
there was continuous distortion throughout the webinar until we changed the mic 😄 . Sometimes fault is at our end .
Vismyteacher
That 100% describes my situation. And it happens from time to time.  Last week I did nothing new or unusual, but the quality was perfect and my students did the listening test. I switched on the audio. But this week I had to cancel some activities with sharing audio in my KeyNote and Power Point presentations
