Poly Edge 20 registration to Zoom
mdi
Hello
I declared my poly edge 20 phone on the Zoom web portal with its Mac address: xx:xx:xx:xx:xx:xx. On my users Lan switch, I created a specific vlan and assigned it to the phone. Subsequently, I created all the necessary flows as is the case for the zoom application to the zoom cloud servers. The phone retrieves an @IP but I cannot register it on the portal, it remains offline. I looked at the streams between the phone and Zoom no streams are visible on my firewall.
I need help with the process of starting and registering a phone to zoom.
1 ACCEPTED SOLUTION
hi mdi,
Poly edge b20 is a certified zoom phone device and will auto provision if the following conditions are present.  First, phone is either a new phone out of the box and has not been used on some other system or you reset the phone to factory.  Second, your firewall rules permit the phone to reach both poly and zoom.
https://support.zoom.us/hc/en-us/articles/360001299063-Zoom-Phone-Certified-Hardware
Check to see that your firewall has the appropriate rules for poly and zoom as specified by poly and zoom in the links below.  zoom will let poly know that your poly phone is registered with zoom.  your poly phone will contact poly first, poly tells the phone where to go to get its provisioning (in this case to zoom) and then zoom takes care of the provisioning.  You should take a look at the firewall logs to see activity between the poly phone and your firewall.
https://support.zoom.us/hc/en-us/articles/201362683-Zoom-network-firewall-or-proxy-server-settings
https://docs.poly.com/bundle/pdms-sp-ag-current/page/required-ports-and-trusted-ip-addresses-and-hos...
for more information, please visit these zoom links.
https://support.zoom.us/hc/en-us/articles/360033223411-Getting-started-with-provisioning-desk-phones
https://support.zoom.us/hc/en-us/articles/360021119092
thanks, eliot
14 REPLIES 14
hi mdi,
thanks, eliot
Hello Eliot.
Thank you for reply i will try open firewall rule beetwen my phone and poly this step is missing on my config firewall. I only i authorize my phone to reach zoom.
I will try and let you known if it work.
Hi Eliot,
What will be the process for Poly Edge 20 with OBi version ?.
Do we need to upgrade the Poly edge 20 with UCS version?
is only UCS version supported with ZTP ? is OBi version also supported ?.
if we want upgrade the Poly Edge 20 OBi to UCS version ??.
Hello
My phone is now registeted to zoom
i open both rules poly and zoom
i forget open dns server from ip phone poly that is why it not work at first
So it ok for me only NTP not work for me. I open my ntp server from my lan it seems be not working.
Thanks it work now for me you ideas help me
hi yogesh_vrtx,
Which part number do you have:
PART NUMBERS
  • • 2200-49800-001: POLY EDGE B10 IP PHONE,PSU,NA/JA
  • 2200-49800-012: POLY EDGE B10 IP PHONE, PSU,ANZ/NZ
  • 2200-49800-022: POLY EDGE B10 IP PHONE,PSU,CN
  • 2200-49800-101: POLY EDGE B10 IP PHONE,PSU,EU
  • 2200-49800-102: POLY EDGE B10 IP PHONE,PSU,UK
  • 2200-49805-025: POLY EDGE B20 IP PHONE,POE
  • 2200-49825-025: POLY EDGE B30 IP PHONE,POE
poly-edge-b-series-ds-en.pdf
please see attached admin guide for software related questions.
Using UC Software configuration files, you can provision and configure your phones, and you can include a mix of UC Software parameters and OBi Edition parameters within the configuration file.
UC Software Configuration on Poly Edge B Series IP Phones
Please see link below to poly for additional poly edge b series documentation
Search Results (poly.com)
for zoom, you should use the supported fimware version
Edge B20AES-1281.1.0.63559/17/2023
thanks, eliot
Hi @Eliot
We have a part -  3111-49805-001  and software version -  1.1.0 (Build: 6355)
mdi
For me my devices is :
Edge B20
6565782149
6565782149
8888
PHONG
ONG
NET
ỶE
