Ready to set up and use Zoom, but aren't sure where to start? Begin with our onboarding support experience for everything you need to get started.
Get Started
Screen share delay and no audio with share sound on Linux
zoomin
I am running Fedora Linux 35 with X11 graphical environment.
Since updating to Zoom client 5.9.1.1380-1, there is a significant delay approximately 1 - 2 minutes from the moment I click share screen with the share audio option ticked. When the shared screen is highlighted in green eventually, participants can see the screen but no audio is heard by participants aside from the audio coming through my microphone.
However, share screen with share audio unticked usually shares within seconds.
I have tried reinstalling the Zoom client (uninstall Zoom and remove local configs then reinstall).
Switched from Wayland to X11. (Screen share was not working at all on Wayland).
Any guidance would be much appreciated.
4 REPLIES 4
tu3
Observer
I'm having the same issue. Hoping a solution can be found.
Doink
Observer
Same issue running Debian 10 based OS.  Had to improvise on a project when it didn't work, sad...
zoomin
Still an issue and it would be helpful if Zoom can acknowledge if a fix is in the works.
@YaBoiBare you able to advise?
YaBoiB
Community Champion
Hello @zoomin
 Yes, a fix is in the works now. We are targeting a future release version to be determined. If you look back at previous replies to this thread. I mentioned it.
Thanks,
Brandon
If this response was helpful for you, please do not forget to click on the accepted solutions button!
