2022-04-05 09:52 AM
I have never used OBS before, but I've got it set up exactly as it says to do in numerous tutorials. I've used VB virtual audio cables and Voicemeeter and neither of them work...EXCEPT when I am testing the mic and speakers in Zoom and even then it is choppy. Everything in OBS is properly configured, and everything in Zoom is properly configured. I'm using Windows 10 with most recent Zoom desktop client and I don't know what else to do. It's very frustrating, especially because I can hear the sound to some extent when I'm testing. As soon as I click out of the test window, the sound cuts out again.
Anyone know how to deal with this?
2022-04-05 07:55 PM
@cantormike – it’s pretty difficult to diagnose something like this without being “live”, but here’s a few things to check:
You might have already seen it, but take a look at this Zoom Support article for some testing and setup guidance.
Come back with any new details and I’ll see what else I can recommend.
2024-11-14 03:37 PM
I may have experienced this same issue. I found a workaround.
A short description of what I observed is that my OBS program audio was making it through OBS just fine. It was being fed into a VB-Audio Cable which was then connected to the ZOOM mic input. I was able to verify that the OBS Program audio did appear at the end of the VB-Audio Cable by using its GUI. However, Zoom was not indicating that there was an input signal.
During testing we found that it was ZOOM that was the sole culprit.
This is how we discovered what was happening.
Background noise suppression
If you click on “Original Sound for Musicians” The four choices under Background noise suppression disappear.
One would assume that this disables the Zoom audio processing, however THAT IS NOT WHAT HAPPENS.
Whatever setting it was in when the “Original Sound” selection was made is what the system stays in. It does not turn off the processing. Since the default was Auto, Zoom decided that the incoming signal needed to be muted.
All that was necessary to “fix” the issue was to switch the choice to “Low”. There isn’t an OFF option. If you then check “original sound for musicians”, Zoom stays in this state. It is still filtering in the Low level but at that level enough of the signal makes it thru to be usable.’
2025-01-18 12:18 AM
thansk you
