Audio Issues
RyannJulie
Having audio issues that started this week. Auto (spoken word) works with minor cut out. When playing auto, music, jiggles, audio files, audio totally cuts out. In the audio test setting when testing audio the audio cuts out as well when doing a test. It starts to play then stops and meter still moves with no audio.  Check other apps and conference apps on computer audio works on all apps except zoom.
Spec: Asus Zenbook, Built in Speakers, i7 12 gen, Windows 10.
Steps to troubleshoot
-Uninstalled Zoom and Resinstalled
-Check for Windows update
-Delete audio driver for speakers and reinstalled
-Check other apps
-Checked network connection 400 mb/s
-No fancy audio setting, all set to default.
Any one else having this issue?
4 REPLIES 4
RMGallagher
Have the same issue. Weird when you click test audio in setting it starts to work then fades out.
sachinzoom
Hello there,
Please try these troubleshooting steps to see if fixes your audio issues:
https://support.zoom.us/hc/en-us/articles/7302459648397-Troubleshooting-audio-issues
Jameswalter
Participant
In the Zoom desktop client, go to Settings > Audio > Music and Professional Audio. Enable that setting. Enable High Fidelity music mode. Once in the Zoom meeting, you can enable "Original Sound" by clicking in the top left corner.
nailmusic
I'm having what I can only describe as a similar issue: When teaching piano, when the student plays their piano the audio quickly fades to zero. When they speak the sound comes back.
I have tried every combination of settings with multiple students and the the problem persists. This only started a few weeks ago; everything was fine before March 1st. As a professional musician and audio engineer I have troubleshooted many different issue across multiple software platforms. I can only assume it's a softwre related problem (using the desktop client on Mac). All my hardware is functioning and I have no issues with any other software, or with zoom meetings consisting only of talking. Any help is appreciated.
