registration not required?
hscheuffele
Do attendees HAVE to register for a zoom event or is it possible for me to send attendees a direct join link or otherwise invite them without them registering?
Background: I am hosting an event that has registration on a different portal and, in the past, we had people register on that platform AND register through zoom which is a lot of steps for them. Is there any way to avoid the second step and just have people able to join the event without registering?
I have seen the pre-registration option which is possible (I have emails for those who register) but I don't see anywhere if I can continue to "pre-register" people after the event has been published.
1 REPLY 1
Calvo
Hi @hscheuffele
when you create a meeting/webinar/event you should be able to set or disable the option "requiere authentication to join" also activate the waiting room and add a passcode for your event under the section meetings in the webportal (your account). Same settings can be found on the desktop client.
BR
calvo
Let's be realistic. Let's do the impossible!
