Zoom AI Companion2023-11-14 12:50 PM
We've been using Zoom Phone for a couple of years now. I've always noticed that tak,ing calls via the Zoom app on my cell phone over wifi or cell network is pretty "laggy".. a normal mobile call is MUCH better. Is there any reason for this? more importantly... any fix for it? I've had other users recently tell me the same thing, so hopefully there's something that can be done.
2023-11-21 05:43 AM
hi joebrug,
could be an issue with your wifi and or internet connection. generally, speeds drop off quickly as you move farther away from the wifi router or access point. to test, try making a call close to the wifi router or access point. sometimes the cable modem and wifi router are contained in one device commonly called a gateway.
if the cell phone is not getting a good wifi signal, it usually automatically switches to cell network. generally, cell phone voice is given priority over cell data.
please see zoom wifi article. if you are using a cable modem, make sure that it is docsis 3.1 which is the current version.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0061805
you can test turning off wifi on the cell phone to force the use of cellular data. then use the cell phone to make a zoom phone call and see how it works.
thanks,
eliot
2023-11-21 06:30 AM
It could be Interference from other Wi-Fi access points (including your neighbors). Best performance is always using a wired connection.
Regards
