Zoom AI Companion2024-03-08 10:06 AM
If my current Auto receptionist is set for GMT-5:00 (eastern) to roll at 2am and we have DST this weekend, will the Auto receptionist automatically know it is DST and calls will roll at 2am still or do I need to manually change the Auto receptionist to push to the call queues?
2024-03-08 11:12 AM
Hello @mnielsen ,
I have been managing Zoom Phone for a large university campus for the past 3 years. It has been my observation that Zoom Phone will automagically account for DST.
I have looked for any documentation that supports this and have even reached out to a few Zoom Phone engineers without any luck. If I find anything more about this in the next 24 hours I will update this post.
So.. I wish I could tell you that it will 100% work and that at 2 AM your calls will roll as expected, but unfortunately all I can give you is a solid SHMAYBE ?!? ¯\_(ツ)_/¯
Cheers!
2024-03-08 01:36 PM
Hello @mnielsen
The answer is yes if you chose the correct GMT-5 Timezone in the configuration: Please notice there are multiple GMT-5 and depending of the "Location", you will find that some support DST and some don't. I.E. If you select "Bogota GMT-5 " or "Lima GMT-5", there will be no Daylight Savings change observed.
Make sure you have the correct "Time Zone" Location selected and you should be fine.
Regards,
Vinnie.
2024-03-15 10:55 AM
