Zoom AI Companion2024-02-09 12:21 PM - edited 2024-02-09 12:31 PM
After my zoom updated to 5.17.5 (29101), I started to notice crackling/popping from my USB speaker/mic (Jabra Speak 510). The crackling/popping comes and goes and sometimes is really bad and sometimes is minor. It doesn't happen when I send audio through my Macbook speakers, only when using the USB speaker.
I've tested various settings, and it seems to be better if I switch audio settings to
- Original sound for musicians
- High-fidelity music mode: On
- Echo cancellation: On
- Stereo audio: Off
But even with the above settings, the crackling/popping still happens sometimes (just less frequently).
Has anyone else seen something similar?
2024-02-10 08:50 AM
Hi j3d,
Do you have the latest firmware/software installed on your Jabra speak 510?
Jabra Speak 510 | Jabra Support
try removing and reconnecting your usb connections from your Jabra speak 510 and your mac book.
Please also see
Troubleshooting speaker or microphone issues in the desktop client - Zoom Support
Troubleshooting audio issues - Zoom Support
Troubleshooting audio with USB extenders - Zoom Support
thanks, eliot
2024-02-16 08:42 AM
2024-02-16 08:53 AM
Unfortunately neither of @Eliot's suggestions helped. I tried force updating the firmware and I've tried connecting the Jabra to multiple USB ports. I'm able to reproduce the problem in Facetime as well as Zoom, so I'm talking to Jabra support now.
