Zoom AI Companion2022-11-22 01:26 PM - last edited on 2023-08-09 01:37 PM by RN
I had to add another call queue, and I'd like to move it up in the option list (i.e. it's now Press 6 and I'd like it to be Press 4). I couldn't see an option to do that. Anyone know how?
Solved! Go to Solution.
2022-11-23 08:20 AM
Hi @mspiegel
Ah I understand. There isn't a way to drag and drop or move them sequentially with arrow keys. When you click the Edit button under the current IVR Menu, you will see the list of actions in numerical key order. Click the word Edit to the right of Key number 4, doing so will show what is currently defined for the Key as an Action.
You will then need to Edit key 6 in the list and set up as it was previously on Key 4.
Does that make sense?
See attachements.
2022-11-22 02:06 PM
HI @mspiegel
The button to Edit the IVR Menu is below what you previously set up. See attached.
Think about changing the Greeting Prompt to verbally match the change you make to the menu option. 😉
I hope that helps!
2022-11-23 05:46 AM
Craig-
Thanks. I found the Edit screen, but when I open that it doesn't allow me to re-order the keys. I tried opening each queue but I can't change the key there either.
I'll definitely change the greeting once I figure this out.
2022-11-23 08:20 AM
Hi @mspiegel
See attachements.
2022-11-29 12:08 PM
Yes!! Thank you!
2022-11-29 12:26 PM
Yay! You're welcome! 😊
