Current option is to turn off all notifications if you are in a meeting, and you can do that in the phone settings by setting "Hide incoming calls while in a meeting".
If you would like to suggest a change to the options, I would recommend submitting a feature request with details on how you would like it to work.
If this helps answer your question, please click on the 'Accept as Solution' button below.
