DND not showing as busy on BLF's Yealink T54W phones
jvogt
When our users put their phones on DND it doesn't change their BLF on the rest of the phones to red so others in the company don't know they are not available.
6 REPLIES 6
sachinzoom
Thats expected behavior currently. Please follow this KB:
https://support.zoom.us/hc/en-us/articles/360038946292-Quick-start-guide-for-Poly-VVX-series-phones#...
FORE-Craig
Hi @jvogt
Actually, what @sachinzoom is partially not true. For Yealink phones, if you turn on DND the status does sync between a Yealink desk phone, and the the desktop and mobile Zoom apps in either direction. I'm not sure if it turns the BLF key for other users to show red if I have my DND on. I'll have to play with it and let you know. We use Yealink VP59s, T54Ws, and T58As. I'll let you know,
I hope that helps!
Craig
sachinzoom
@FORE-Craig Its quite possible that certain phones do some DND syncing. I will also have to test to see if this article needs to be more specific.
jvogt
@FORE-Craig   90% of my users are on T54W's only.. No apps.  Their DND doesn't sync just had it tested on multiple devices.
FORE-Craig
Hi @jvogt
When I say 'sync', I mean that turning on DND on the phone activates DND in the Zoom desktop app and Zoom mobile app.
I tested with our phones, and shockingly the DND setting does not turn the line key lamp red, nor the onscreen silhouette on the phones like, as it does when the user is on a call, as one would expect. There is also no visual queue next to the Contact in the Zoom desktop app or Zoom mobile app. It is kind half-baked! Hahaha
I suggest that we both submit feature requests for this.
Craig
sachinzoom
Hi ! You have some responses to your discussion worth noting. Have any of these answered your question? If so, don’t forget to mark the reply as an accepted solution!
