Zoom AI Companion2022-03-03 01:13 AM
We are in the process of switching over to Zoom phone and i would like to keep using our desk phones (Yealink T41S) if possible.
I however found out they are not in the list of compatible desk phones.
Is there maybe some way to get them to work?
Solved! Go to Solution.
2022-03-03 06:45 AM
@Yilmazer You are correct, the Yealink t41s is not a Zoom Phone Certified Hardware so this will not work. I suggest that you invest in any of the Certified ones.
In addition, please note that some devices are already end-of-life (EOL): (but still works with Zoom Phone)
2022-03-03 06:45 AM
2022-03-04 12:58 AM
