Original sound fades when turned 'on' using Mac
chris4ord
I've only noticed that the sound I play through OBS to Zoom fades after a few seconds even though Original Sound for is turned 'on'  is there a fix for this? I've tried to use the background suppress 'low' as an alternative but that isn't any better.
Thanks
1 REPLY 1
bstrelko
Which virtual audio device are you using to transport audio from OBS' output to Zoom's input?
Which OS and which versions of Zoom/OBS are you using?
Did this issue start recently or has this always been the case on your setup?
This info will help to inform next steps.
