Zoom AI Companion2023-02-13 09:43 AM
Hi there,
I am trying to install zoom on my mac and it keeps saying installation failed. When I first tried to install it, an apple command popped up that I clicked not to allow, and I am concerned that this has affected me being able to download the app successfully. Please help!!
2023-02-21 04:51 PM
Hi @HannahB1 , thank you for your contribution to the Zoom Community. I'm sorry to hear that you are having issues downloading Zoom on your Mac.
Let's try the below steps and let me know if it helps:
Note:
If the installer is not seen at the above location, please add it manually by going to Finder > Go > Go to Folder...- key in /System/Library/CoreServices/Installer.app and then add the installer once the option is listed.
I hope this helps!
Carla,
Zoom Community Team
Please click Accept as Solution if you found this reply helpful. Thank you!
2023-04-13 11:12 AM - edited 2023-04-13 11:12 AM
Hi @HannahB1 was @CarlaA's reply helpful? If so, great! Just don't forget to click that 'Accept as solution' button! 😉
Otherwise, wanted to mention, our Knowledge Base Article on Troubleshooting issues with Zoom update and installation. It contains helpful recommendations that can assist you in resolving the issue. Please give it a read and let me know if you're able to install/update Zoom.
