Zoom AI Companion2024-02-26 08:55 PM
Hello?
We have encountered some issues while using Zoom. We would like to inquire about the following issues:
We would like to confirm whether these issues are related to Zoom's platform. If so, could you please provide us with information regarding the cause and potential solutions?
Solved! Go to Solution.
2024-02-29 11:14 PM - edited 2024-02-29 11:15 PM
Check audio and video latency in settings > statistics. Typical delay is about 30-40 ms. Most excessive delays are the result of insufficient CPU (i7 recommended, i5 minimum, i3 is not adequate) or insufficient bandwidth or from using WiFi, especially with a week signal. Remember that viewing realtime handwriting uses upstream bandwidth which can be limited. Ethernet is always recommended instead of WiFi since WiFi must double process the encoding/decoding of the streams. If teachers and students are on the same network then bandwidth can disappear very quickly.
