Zoom AI Companion2021-10-02 12:00 PM
I want local recordings to use multi tracks but when I go to the "Recording" "Settings" there is not an option to select.
Help is appreciated. Thanks
Solved! Go to Solution.
2021-10-02 12:55 PM
Hi @rksjames
Are you looking for separate audio tracks for each participant when recording locally?
This should be in the Recording tab of your desktop Zoom app - see below.
Please note local recording does not provide isolated video recordings of each participant.
Also the separate audio tracks are only available in the desktop client - not mobile or web.
If you are Cloud recording, you have more options for video (but still not each participant) - but in the Cloud you cannot record separate audio tracks. https://zoom.us/profile/setting?tab=recording See second screen shot.
What version desktop client do you have?
2021-10-02 12:55 PM
Hi @rksjames
2021-10-02 01:05 PM
Thank you Rupert. I was trying to do this with browser access.
Have a great day!
2021-10-02 01:06 PM
You're welcome. Happy to be of help!
