Apr 16, 2026 9:02 PM UTC
Need help exporting transcript of "My Notes"
When I try to export “My Notes” from a meeting, it lets me export the “summary” with no problems, but when I try to export the “transcript”, it only exports the title of the meeting without the transcript.
I’ve tried all the solutions google has found for me but none of them worked.  I’m hoping someone can help me.
Thank you.
Aug 5, 2026 12:42 AM UTC
Hi, everyone.  What I hear is the you want to download the Transcript of a meeting from My Notes, yes?
Go to your Workplace app, and click the Hub icon (gold box on the left), and click (green arrow) on the meeting you want the transcript from.
Once you click on the meeting, click on the Transcript button (green arrow below) to see the transcript window (gold box below).
Look for the download icon!  Once you click that, there’s the usual Save As file dialogue, where you can pick a folder and type a file name.
I do wish there could be a better default filename than “transcript.txt”, but it’s easy enough to type in whatever you want to call it.
If that’s NOT what you’re looking for, let me know!
Jul 22, 2026 8:24 PM UTC
+1 to this entire thread.  “Truly scummy behavior” that is “hostile to the customer” and serves only product bloat.   The goal seems to be to trap users in an ecosystem they don’t want to be in.  I’m now actively seeking alternatives.   Zoom took a good product in a very wrong direction.
New Member
Jul 22, 2026 8:52 PM UTC
New boomarklet that supports the latest Zoom changes.
https://kdttocs.github.io/zoom-to-markdown/
New Member
Jul 22, 2026 8:54 PM UTC
New bookmarklet that support the latest Zoom changes.
New Member
Jul 22, 2026 9:08 PM UTC
Paid Pro member here with hundreds of users in my org that rely on this feature. Maybe Teams isn't so bad after all!
New Member
Jul 23, 2026 1:13 AM UTC
This is frustrating. Now I cannot download the raw transcript of my notes. I’m starting to enjoy its capability and now they do this. I guess back to using Microsoft Teams!
New Member
Jul 23, 2026 8:26 AM UTC
HEY, Zoom! Why cannot we select/export the transcript anymore? It is a crucial part of our workflow, and your note summary does not take any context in consideration.
Why do you do this? Where are comms for this? You are breaking the workflows of your Enterprise users, and this is getting unbearable!!!
New Member
Jul 23, 2026 4:28 PM UTC
Any update on this? I’m sure it was an intentional change that needs to be reconsidered. You don’t improve a platform by removing features from users who pay for the platform. Not a move in the right direction. This needs to be turned back on asap. Please respond. This issue is not going away!!!
New Member
Jul 23, 2026 6:26 PM UTC
Copying the transcript from “my notes” has been completely blocked (apparently) since yesterday. Now you must wait for the transcript to upload in the zoom web app and download the .vtt file to achieve the same thing, which is significantly more time consuming.
Chiming in to support everyone’s dis-satisfaction with this change.
New Member
Jul 23, 2026 10:01 PM UTC
Jul 24, 2026 4:13 PM UTC
Hello, everyone!
Thank you for your patience while we investigated this issue.
We found that this behavior was caused by a recently released setting that allows organizations to disable copying and downloading of My Notes transcripts. Due to an issue during the feature rollout, this change unintentionally affected some users.
Update: We've rolled back the change, and the previous behavior has now been restored. You should once again be able to download transcripts where applicable.
We apologize for the inconvenience and appreciate your patience while we worked to resolve this.
If you're still unable to download transcripts after the rollback, please let us know. We'll be happy to investigate further with you.
Jul 27, 2026 2:04 PM UTC
Thank you!
