Jun 18, 2025 2:03 PM UTC
Zoom.exe Entry Point Not Found AppData\Roaming\Zoom\bin\viper.dll
I am zoom subscriber for 4 years, today when i tried to launch zoom it pop up message saying
Zoom.eve - Entry Point Not Found
The procedure entry point GetThreadDescription could not be located in the dynamic link library
c:\user\xxx\AppData\Roaming\Zoom\bin\viper.dll
I tried to uninstall zoom
delete the folder c:\user\xxx\AppData\Roaming\Zoom
reinstall, but still the same
i also tried to reinstall Microsoft Visual C++ 2-13 redistributable (x64) 12.0.3051
and also reinstall Microsoft Visual c++ 2008
did try to sfc /scannow
and restart
and reinstall but still the same
i still able to use zoom on my desktop on yesterday morning
i am using window 10 x64bit with up to date updates
please guide, thank you
ZMUSer1Answer
Jun 19, 2025 6:47 PM UTC
Sep 4, 2025 12:11 AM UTC
En el video explico posible solucion.
https://www.youtube.com/watch?v=HDC33srzj6Q
New Member
Jul 14, 2026 1:56 AM UTC
Because Zoon as a Microsoft program, Microsoft wants you to use Microsoft 11 only. I hate Microsoft 11 because they MAKE you sign in Microsoft every time. To me, I alone have the right to choose what Window i use. I like 10 NOT 11. This “c:\user\xxx\AppData\Roaming\Zoom\bin\viper.dll “is for 11 to run. That's why changing to previous version worked for some, did not foe me. So I’ll keep trying.
I found this to try next......    Microsoft pushes Windows 11 so heavily because it integrates deeply with Microsoft 365 and their cloud services. Also, Windows 10 reaches end-of-life on October 14, 2025, making updates essential for security. If you are getting unwanted upgrade or software prompts, you can disable them in your settings.
To stop those constant prompts and keep your setup as-is:
  • Block Office Prompts: Go to Settings > Apps > Installed apps, find Microsoft 365, and click Uninstall. You can also disable Office background tasks in Task Manager to prevent background interruptions. [1]
  • Stop Windows Tips: Go to Settings > System > Notifications and toggle off Suggest ways to get the most out of Windows and Get tips and suggestions when using Windows
