Jun 18, 2025 2:03 PM UTC
Zoom.exe Entry Point Not Found AppData\Roaming\Zoom\bin\viper.dll
I am zoom subscriber for 4 years, today when i tried to launch zoom it pop up message saying
Zoom.eve - Entry Point Not Found
The procedure entry point GetThreadDescription could not be located in the dynamic link library
c:\user\xxx\AppData\Roaming\Zoom\bin\viper.dll
I tried to uninstall zoom
delete the folder c:\user\xxx\AppData\Roaming\Zoom
reinstall, but still the same
i also tried to reinstall Microsoft Visual C++ 2-13 redistributable (x64) 12.0.3051
and also reinstall Microsoft Visual c++ 2008
did try to sfc /scannow
and restart
and reinstall but still the same
i still able to use zoom on my desktop on yesterday morning
i am using window 10 x64bit with up to date updates
please guide, thank you
ZMUSer1Answer
Jun 19, 2025 6:47 PM UTC
Jun 19, 2025 1:58 AM UTC
Same issue on all my workstation here.
Jun 19, 2025 2:00 AM UTC
Same here,on all my workstations
ZMUSer1Answer
Jun 23, 2025 4:29 AM UTC
by installing previous version had solved
Zoom.exe Entry Point Not Found AppData\Roaming\Zoom\bin\viper.dll issue
Thank you @LK_EXN
hope the next version won't have this issue
Jun 23, 2025 8:54 PM UTC
I had the same problem. I went from Version 6.5.1 to 6.4.3. At least it seems to have installed correctly without any error message. I'm keeping my fingers crossed on whether everything works correctly for a meeting this evening.
Jun 23, 2025 7:04 PM UTC
Zoom's written in qt6. Seems that API of windows_10_ltsb_2016 doesn't support "get/setthreaddescription", but qt6 requires that functions recently. New version of Viber has the similar issue.
Jun 24, 2025 12:51 PM UTC
Same here on AWS Workspaces Windows Server 2016 OS.
Windows 11 working fine.
We're testing rolling back to previous versions..
Jun 24, 2025 3:18 PM UTC
Failed versions:
6.5.1.6476
6.5.0.6118
Working versions:
6.4.12.64384
Zoom support case raised, the first answer from probably first line support was to refer to this article:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0070085
Where they ask to "reinstall Microsoft Visual C++ 2008 Service Pack 1."
This is annoying if we have to do that... I've asked to escalate it.
Jul 10, 2025 8:22 PM UTC
Hello @WinZoomer,
We're sorry for the inconvenience you experienced.
Upon checking, our Technical Support Engineer (TSE) is currently reviewing your concern and is awaiting additional information in order to proceed.
Kindly reply to the ticket with the requested details at your earliest convenience so we can continue troubleshooting and work toward a resolution.
Have a great day!
Jul 11, 2025 2:31 PM UTC
@MGSR I have updated to the latest again & tried the Zoom article KB0070085 that (WinZoomer) mentioned to which the issue persisted. We have reverted back to an older version again.
Jul 11, 2025 12:45 PM UTC
Have the same issue since the June and July monthly updates we do for the Zoom.  Going back to the May release 6.4.x fixes the issue.  I have a case open - TS1915522, that is going no where.  Please help.
Jul 12, 2025 4:58 AM UTC
take a look at the following for insights on this issue
https://appuals.com/fix-the-procedure-entry-point-name-could-not-be-located-in-the-dynamic-link-library/
Jul 29, 2025 4:14 PM UTC
Still experiencing this issue on Windows LTSB 2016, which is supported by Microsoft until October 2026.  Downgrading is not a long term solution, due to Zoom's quarterly lifecycle policy https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0061130
Jul 31, 2025 5:14 AM UTC
The issue was introduced on Windows zoom client 6.5.0 where we used the Windows system API GetThreadDescription, while we found that the Windows system DLL kernel32.dll does not contain this function on some old OS, we will fix it on zoom client 6.5.10 which is scheduled for August 18th. Workaround is to install zoom clients older than 6.5.0.
