Jan 17, 2025 3:31 PM UTC
Default voicemail greeting for company-level holiday hours
In the company overview account settings, I am able to set the default voicemail greeting for most things, however it seems I can't do it for holiday hours.
I've got standard holidays programmed in for the whole company which apply to all extensions. As far as I can tell it only lets me change the voicemail greeting per holiday, per auto receptionist/call queue/user, which is just way too much manual work for the number of destinations we have.
Am I missing something, or is there truly no way to do this?
Aug 31, 2026 8:48 PM UTC
hi ​@JOHN MCCREERY
screen shot
Aug 31, 2026 8:49 PM UTC
hi ​@JOHN MCCREERY
screen shot
eliot
Aug 31, 2026 8:51 PM UTC
hi ​@JOHN MCCREERY
screen shot
eliot
Sep 1, 2026 2:58 PM UTC
Thank you for the reply, I have those set.  But just trying to come up with a company wide calendar that would follow the after hour routing so I don’t have to go to 20 different Auto Attendants and set up for a holiday.
Sep 1, 2026 3:11 PM UTC
hi ​@JOHN MCCREERY
you can have one company wide calendar and target many auto receptionists.  each auto receptionist that is targeted will have the company wide holidays added to its list of holidays. each auto receptionist will follow the company wide calendar and its own after hours routing.  practice a auto receptionist will send holiday calls to the practice a answering service, practice b auto receptionist to practice b answering service.
i did not use the call handling options.  these are limited as you point out.
