Jan 17, 2025 3:31 PM UTC
Default voicemail greeting for company-level holiday hours
In the company overview account settings, I am able to set the default voicemail greeting for most things, however it seems I can't do it for holiday hours.
I've got standard holidays programmed in for the whole company which apply to all extensions. As far as I can tell it only lets me change the voicemail greeting per holiday, per auto receptionist/call queue/user, which is just way too much manual work for the number of destinations we have.
Am I missing something, or is there truly no way to do this?
Vinnie
Feb 11, 2025 10:37 PM UTC
Hello @josh_swr , you should be able to define the following Defaults at the Zoom Phone location level according to what I can see in my Zoom settings (It is an Enterprise account but I assume it should be the same for any account):
Default Business Hours: Set the default business hours for all users, Zoom Rooms and common areas for the site.
Default Overflow for Business Hours: Set the default overflow for business hours for users, call queues and shared line groups.
Default Overflow for Closed Hours: Set the default overflow for closed hours for users, call queues and shared line groups.
Default holiday hours & force majeure events: Set the default holiday hours & force majeure events for all users, Zoom Rooms, common areas, auto receptionists, call queues and shared line groups for the site.
Default overflow for holiday hours & force majeure events: Set the default overflow for holiday hours & force majeure events for users, call queues and shared line groups.
Go to your Zoom Portal:  ADMIN > Phone System Management > Company Info. In my case I need to select the specific location as I have it setup for Multisite, and there there are the "Hours" defaults I described before. Other Defaults and Templates can be defined there.
Let me know how it goes and if this helped, please don't forget to mark this post as a solution.
Vinnie
Feb 18, 2025 12:33 AM UTC
I am having a similar issue to Josh. I have set all my holidays (manually for each holiday) and created a greeting prompt & IVR but when I call the main line today (Presidents Day), it goes to some default greeting prompt. I have changed it to the holiday greeting everywhere I could find the option but it's still the same default prompt when I call. (And I'm frustrated because I can see in the logs that other people are calling & getting this default greeting.)
I'm missing a step but nothing in the kb articles is matching what I'm seeing or providing the detail I need.
I guess I have until Memorial Day to sort this out.
(fwiw, we're Business not Enterprise level but it should be the same)
Vinnie
Feb 18, 2025 3:08 PM UTC
Hello @SkylarC
I have been using Zoom Phone for over 4 years and I know it works as I described to @josh_swr on my previous comments; even more, I've just tested it adding Holidays adding it to in the "Zoom Phone Location" configuration and it actually updates all the Users/Call Queues and Auto Receptionists for that location.
❓Do you mind providing more details about your setup and what steps are you doing to configure the Holiday(s)? I would like to understand what is it that is not working in your case
Feb 18, 2025 5:09 PM UTC
I'm sure it works but I am clearly missing a configuration setting.
Under Phone System Management>Company Info>Hours I have set Business Hours & Default Holidays & force majeure events.
Under Auto Receptionists>Main Auto Receptionist>Holiday List & Call Handling, under Greeting Prompt for each holiday, I added a holiday greeting recording.
As I'm going through menus, it appears that I may need to put that Holiday greeting under Call Queues instead (or in addition to?)
Call Queues>Main Line>Holiday List & Call Handling
I am really a novice at this (but generally pretty tech savvy). The specifics are probably obvious to someone familiar with phone systems but not well documented for those of us who are not.
Vinnie
Feb 18, 2025 8:08 PM UTC
To change the "Default Prompts" it is also done in Zoom Phone Account Settings, but on the left submenu, look for "Audio Prompt" and you will see "Default Audio Prompt - Manage" (Manage greetings, audio while connecting, and hold music for all Users, Zoom Rooms, Common Areas, and Cisco/Polycom Rooms under this site.)
Consider this will change those default prompts for everything under that particular location that is using Default Prompts:
"Greeting & Leave voicemail instruction" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Greeting & Menu: Leave or check voicemail" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Greeting & Menu: Connect to operator or leave voicemail" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Greeting & Menu: Connect to operator, leave or check voicemail" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Leave voicemail instruction" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Message Greeting" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Audio While Connecting" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
"Hold Music / Music on Park" (independently for "business Hours", "Closed Hours", "Holiday Hours" )"Leave voicemail instruction" (independently for "business Hours", "Closed Hours", "Holiday Hours" )
Feb 19, 2025 2:44 AM UTC
I don't think that's it. I had found that yesterday and changed all the holidays to the holiday greeting but it still played a default greeting. (Interestingly, business & closed hours are all "default" for these but the correct main greeting plays for both.)
Aug 27, 2026 4:20 PM UTC
We are a large medical organization that has multiple practices that each have their own answering service number, I need to be able to go to one place and set a holiday schedule and it follow whatever afterhours call flow that is set for the auto attendant of the practice in question.  It can’t only be set for a site because we may have up to 6 different practices at one site. Everything from Allergy to Surgery.
Aug 29, 2026 2:39 PM UTC
Hi ​@JOHN MCCREERY
Because this appears to be case of multiple practices at multiple sites, a little more detail would be helpful.
Do all calls for the practices come in to your medical organization’s main number?
Does each practice have the same business hours no matter what site(s) an individual practice is located in, or do hours vary depending on site, or are business hours set the same by your medical organization for all sites and practices?
Does your medical organization have its own auto receptionist and IVR to select requested practice?
Does a practice provider work at only one site or may a provider work at multiple sites?
Does each practice have one auto receptionist and IVR to select services and that uses the same after-hours answering service or does each practice have an auto receptionist at each site and uses the same after-hours answering service?
Under one scenario, you could have your medical organization business hours and holiday schedule that is followed by all sites and practices.  During non-business hours, auto receptionist IVR could transfer calls to the desired practice answering service based on caller’s IVR selection.
For some good support articles on auto receptionists, IVR, and sites, please see below:
Managing auto receptionists
Changing auto receptionist settings
Creating an interactive voice response system
Managing multiple sites
Changing site-level settings
thanks, eliot
Aug 31, 2026 5:19 PM UTC
No, Each practice has there own main number that rings into their own auto attendant that goes after hours, weekends, and holidays to their own answering service phone number.
All practices have their own business hours including different closings for lunch.
We do have some practices that are multiple sites but the only number published is their main number assigned to their main auto attendant.
Our main campus has 10 different practices at that location all with their own auto attendant and ques. I created a separate site for our imaging department just to be able to have separate settings for that area.  I have our Pediatrics practice which has three locations or sites, each with there own phone number and auto attendant that go to the same queue.    I am looking for a setting that would work across all auto attendants and queues in the ZOOM phone system to have there calls route to their afterhours call setup, even if I had to set up a separate routing for the holidays on the auto attendant.
Aug 31, 2026 7:25 PM UTC
hi ​@JOHN MCCREERY
I am looking at Changing business hours, holiday hours, and overflow settings default business hours to see if this might work.
Aug 31, 2026 8:42 PM UTC
hi ​@JOHN MCCREERY
with default holiday groups, you can set up a default holiday group, add holidays, and add targets such as auto receptionists, call queues, etc. this may be something you can use.  please see attached screen shots.
thanks, eliot
Aug 31, 2026 8:44 PM UTC
i am sending screen shots one at a time.
Aug 31, 2026 8:46 PM UTC
screen shot
Aug 31, 2026 8:47 PM UTC
screen shot
