Oct 23, 2024 2:58 PM UTC
Zoom Camera Not Working
Hello -
My camera has stopped working in Zoom calls. It is a built in camera on my Lenovo computer. My Camera app works and my video works on Microsoft Teams and Google Meet. Here are the steps I've done so far
  1. Log out, log back in
  2. Confirmed Security permissions are turned on for the Camera on Zoom
  3. Confirmed my built in camera slider is in the proper position
  4. Confirmed no other application is open using my camera
  5. Upgraded Zoom
  6. Rebooted
  7. Uninstalled and reinstalled Zoom
The camera video feed just remains black and my camera light on my computer slowly flashes a couple of times before stopping altogether. I have received a message once saying the background was taking a long time to load and asked if I wanted to proceed without the background (I had Blur turned on), and I said yes, but it still didnt work. I have since turned blur off and the camera still doesnt work.
VP13Answer
Oct 30, 2024 4:44 PM UTC
Hey, everyone! So I may have found a solution. After speaking with reps from Lenovo (not helpful and trying to charge extra for someone actually good), and then calling Microsoft tech support (not helpful, no live person), there was an answer on help.microsfot.com. One of the posters advised to reinstall Zoom and the camera (which clearly does not work). But the other advised to do the following (which works):
1. Log into Zoom
2. Go to Settings
3. Go to Video
4. Scroll down to Advanced at the very bottom
5. Change Video Capturing Method from "Auto" to "Media Foundation"
This should work.
What I also found works in a pinch, though extremely inconvenient, is logging into the laptop camera and keeping it on while logging into Zoom. It defies logic because the camera technically is open in two concurrent apps and should not be working. But it worked like that as if Zoom camera function was piggy backing on the general camera. But that also meant keeping the laptop plugged in all day and general camera on. I could log in and out of Zoom camera as long as the main one stayed on. The moment I experimented and turned the main camera off and then on and logged into Zoom, it did not work unless I repeated all the steps from going into setting to turning on the camera. So this also works but again, changing video capturing in Zoom should do the trick.
All the best!
Oct 23, 2024 9:27 PM UTC
This happened to me also two days ago and has been persisting. Lenovo was of no help. Zoom as well. I've gone to BestBuy and spoke with Geek Squad twice. They did all the steps you did, and it worked there. As soon as I close the laptop and restart it at home, it's blank again. Something is not sticking.
In a pinch I found this to be helpful, though it's a painful process to go through over and over. Go to settings, find camera, then navigate to Integrated Camera. It should work (this is only a Zoom issue, works well with Teams and Google Meet). Keep the settings camera on and open Zoom. Camera should work (most of the time) while running on both apps. I can't explain this but it works. Sometimes it does not, and you have to start the process again. But for each meeting you also need to start the process again. Zoom will not work if you leave and come back even if you keep the camera on in Settings.
Wonder who can chime in on this.
kdavis1Author
Oct 24, 2024 12:27 AM UTC
Hi there! Thanks so much for the response. This also recently happened to me - I believe it started up yesterday morning after my first call. So frustrating!
The instructions for going to settings... are you going to your Zoom settings or computer? In Zoom settings, I'm still only getting a black screen within Settings >Video or Settings > Background & Effects.
Oct 30, 2024 8:54 PM UTC
Which settings are you talking about? If for Zoom, it's very convoluted. It's not on the Zoom dashboard. You have to log into a Zoom meeting, then left click a little ^ sign next to camera icon on the lower left, click on video setting at the bottom of the pop-up menu. When the window comes up you will see "Advanced" in the middle of the footer of that window. Left click on that. Then choose last of the three "Video" pull-down menus. They should be all set to "Auto" by default. Then you change the last one to "Media"...
Oct 29, 2024 8:58 AM UTC
Simply weird: I began writing a reply then it disappeared after navigating away for a few seconds. My Logi webcam with a USB connection won't recognise Zoom or Google teams, although it shows up as hardware on my Mac. All used to be find with High Sierra, but I've changed to Monterey, since when no camera connection. Zoom told me I can't get help because I've got no account which is r*bbish.
Oct 29, 2024 10:15 PM UTC
This is hapening to me too just as of October 22. Didn't notice previously. Exact same thing though. Lenovo. Camera seems to work everywhere except Zoom. Teams and by itself are fine.
Oct 29, 2024 10:55 PM UTC
Me too!  Also as of October 22nd.  It is so frustrating!  I have sent a ticket in to Zoom.  Crossing my fingers they have a solution.
kdavis1Author
Oct 30, 2024 1:35 AM UTC
Yes!! Mine stopped working on 10/22 as well! It's still not working, but I was able to get an external webcam to plug in via USB, and that works. At least I have a workaround for now...
@MKieffer how did you submit a ticket? Everything I found just kept pointing me to the community boards!
VP13Answer
1. Log into Zoom
2. Go to Settings
3. Go to Video
This should work.
All the best!
Oct 30, 2024 8:30 PM UTC
So - I logged in and went to Settings.  Where is Video once you are in Settings?  I am not finding it anywhere
Thanks in advance for the help
Oct 30, 2024 8:55 PM UTC
Open settings in the zoom desktop app. Then there's Video in there.
Oct 30, 2024 4:48 PM UTC
I just posted a long reply but it disappeared. In short:
1. Go to Zoom Settings
2. Video
3. Advanced Settings
4. Video Captioning Method - change from Auto to Media Foundation
Oct 30, 2024 6:09 PM UTC
Just tried it (Video Capturing). It does work! Thanks!
Oct 30, 2024 8:53 PM UTC
Apr 15, 2025 2:07 AM UTC
Hi.  This solution did not work for me but thank you.  Still get failed to start video camera message.  It worked this morning.
Aug 4, 2025 4:55 PM UTC
I have this problem too - have tried everything.
Aug 14, 2025 5:18 PM UTC
I tried everything as well and couldn't get it to work.  Finally, the next time I joined a meeting Link from my email (I use Microsoft edge browser) I clicked on "open zoom meeting in browser" instead of opening it in the Zoom app, then my video would work. I've done this a couple of times and it's working. But if I try to open the meeting link with the app it doesn't work. Hope this helps.
Oct 15, 2025 4:17 AM UTC
I have this same problem. I recently updated my MacOS to Tahoe on my Macbook Air. Now when I use the Zoom app, it won't load my video. The camera is on, but the video won't load. It did once last week, but it took a while. Today, I had a meeting and the video never load despite my camera being on. I've uninstalled and reinstalled Zoom. But the problem still persists.
