there is no blur background option in my pc though virtual background works | Community
  • August 21, 2021
  • 45 replies
  • 413 views
There is no blur background option in my pc though virtual background works and i      have updated zoom on the latest version ...,,,   There is no blur background option .i have tried by uninstalling and again installing but there is no change  .....,,,       MY SINCERE REQUEST IS PLEASE SOLVE ME PROBLEM .
    I was facing the same issue.
    thanks zoom community for the solution.
    Regards: smith  🙂
    I had faced a similar problem during an online meeting for water main break repair. However, after upgrading, the problem was resolved. It's possible that your system requirements are incompatible, or that you're running an old version of Windows.
    I usually use zoom for wazoodle fabrics but have the same issue of not having a blur background. I think zoom should put this option in their upcoming update version.
    I've the blur option with ALL the apps in my PC-windows 11 i3 12 gen-8 cores, Teams, Meet, Skype...just with Zoom it doesn't work. And it is not a hardware issue...If you guys cannot solve this issue, I shifted all my conference calls to the other apps. Let me know when you solve it. Thanks
    I am having the same problem for the past two years. Have they resolved your issue? Also when you use the other virtual backgrounds, they are grainy and do not show clearly.
    I have a Intel Coffee Lake with 6 cores and 12 logic processors, 32 GB RAM, NVMe storage and I can't enable blur background in Zoom. So there is some problem in the PC capabilities detector algorithm.
