Aug 21, 2021 6:23 AM UTC
there is no blur background option in my pc though virtual background works
There is no blur background option in my pc though virtual background works and i      have updated zoom on the latest version ...,,,   There is no blur background option .i have tried by uninstalling and again installing but there is no change  .....,,,       MY SINCERE REQUEST IS PLEASE SOLVE ME PROBLEM .
    Participant
    Jan 3, 2022 5:08 AM UTC
    Hi @ajaypande @jdott16 is correct you must have those device specifications
    Jan 16, 2022 7:21 PM UTC
    I have a leading edge machine. The specifications issue is a non-issue!
    Jan 7, 2022 6:02 PM UTC
    MacOS Monterey 12.1; 1.8 GHz Dual-Core Intel Core i5
    Zoom 5.9.1
    I think this meets the specifications, but still no blur option on my 2017 Mac Air.
    Jan 12, 2022 4:31 AM UTC
    This is not user friendly at all. I  don't have blur and have the latest Zoom and latest MAC software update.  I even restarted the program and nothing.  There is no blur.
    Jan 15, 2022 12:29 PM UTC
    Same here. I update every Zoom. I have a 2018 MacBook Air with an up to date operating system.
    Jan 16, 2022 7:19 PM UTC
    I cannot believe this fiasco! So many having the same issue as me and not a peep out of Zoom who has been touting their newest feature which doesn't work! I screwed around for half an hour on my Windows 10 64-bit machine, and all of a sudden, a pop-up, I installed it, and there it was! But I have no idea what I did to invoke it.  Thereafter, I have been trying to find this patch, to no avail.. 😞 There is NO such option as Blur under Virtual Background - in fact, there are no other useful menus under VB. Disappointing. Time to move on to some other software.
    Feb 1, 2022 9:03 PM UTC
    I as well am not able to see a blur option on my virtual backgrounds menu on my laptop.  I have updated Zoom to  version 5.9.3 and have the following processor Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz 2.60 GHz which meets minimum specs.  Would greatly appreciate any help which could be provided.
    Mar 2, 2022 12:32 AM UTC
    Updated everything: still no clickable 'blur' option.
    Please see attached.
    Apr 29, 2022 1:24 AM UTC
    Same problem... we just upgraded to Pro so we could use "blur" & not have to use a green screen for virtual backgrounds to work better than they do without (not well).  I have downloaded what seems to be the latest version, as no download came with the Pro upgrade.  "Blur" does not come up as a choice & I can't uncheck the "I have a green screen" box to see if that's the issue.  Called support but apparently Pro doesn't include technical support. Extremely frustrated...
    May 9, 2022 4:28 PM UTC
    You do not need to have a pro account to use "blur background". This feature is hardware dependent, so it's your computer's CPU or GPU that is not powerful enough.
    May 9, 2022 4:27 PM UTC
    Hello! I see that no comment here has been accepted as a solution for this, so I thought I would weigh in!
    The simple explanation is that "Virtual Backgrounds w/out a green screen "and "Blur Background" require significantly more CPU and GPU power than using a green screen, and the Blur Background feature cannot be used with a Green Screen.
    (example of green screen)
    Even if your computer supports virtual backgrounds with a Green Screen, it may not support the more CPU/GPU intense "blur background" feature. If you cannot turn off the green screen option for virtual background, then your computer will not be compatible with the blur background feature.
    While this article https://support.zoom.us/hc/en-us/articles/360043484511  tries to be conclusive about minimum specs, it's a bit lengthy and doesn't have every compatibility/incompatibility listed. It is however an excellent starting point, and if your hardware is lower than the minimums listed here you will not be able to use "blur background" or "virtual background without a green screen".
    Please mark this as a solution if this answers your question.
    Thanks,
    Micah
    May 9, 2022 6:18 PM UTC
    Thanks Micah! I do see now the blur option requires a processor of i5 or above and mine is just i3. I don't know why I didn't notice that requirement earlier. Anyway, at least I have the explanation now. Thanks!
    May 9, 2022 6:31 PM UTC
    Hello MicahHoffman and Thomas852,
    Thanks for your replies. My processor is i5, but I definitely cannot access the blur background.
    Much of the other spec listed in the link provided by Micah, matched up with the System spec information needs to be clearly spelled out for non-techies. I don't know what the mis-match could be.
    May 10, 2022 3:11 PM UTC
    Hi HJ2,
    The processor being an i5 is only half the story, just as important is how old the processor is, how many cores the processor has, and what GPU is paired with it.
    If the blur background feature is missing from Zoom, the most likely reason for it (aside from needing a software update) is that your computer isn't new enough or powerful enough for it.
    Thanks,
    Micah
    CorgiPawPaw
    May 31, 2022 7:06 PM UTC
    I currently have the same issue.  No option to blur my background.  And Yes I meet all the requirements to blur my background.  I do not even have an option key to blur it, so this shows me it is an issue on Zoom's end.  Please fix and let me know.
